Image is squeeze
Discussion in 'GeoCraft WordPress Theme' started by targon, Nov 25, 2015.
  1. targon
    targon New Member
    Hi
    I upload an narrow image but this image was expanded on listing area...
    Is it possible to avoid image to be expanded?? I want natural image !
    see image
  3. targon
    targon New Member
    Ho Priya
    Here it is: http://www.doapet.com.br/listing/dog/
    Let me know how to remove the image adapter (squeeze fucntion) for images inside the listing... I want this images as natural size (high or width) instead to adapt that on width!!
    .flexslider .slides img {
        width: 100% !important;
        height: auto !important;
  5. targon
    targon New Member
    Very thanks PRIYA!! Very good!! It works!!
    Another question: How to translate the theme? There is nothing on documentation!!
  6. priya
    Hello
    You can use "Google Language Translator" plugin to change the current language with your desired one.
    Here's the link of the plugin: https://wordpress.org/plugins/google-language-translator/
    Please have a look on the above link, you will get all the process of activation and use of this particular plugin.
    Or,
    To translate your website in another language, you can create and configure separate .po and .mo files.you can follow the tutorial link given below which will definitely help you to create these files.
    http://www.inkthemes.com/how-to-cre...ion-of-wordpress-theme-in-multiple-languages/
    Hope you will find it helpful..
