Images AMP
Discussion in 'ClassiCraft WordPress Theme' started by taylor50plus, Jan 22, 2018.
  1. taylor50plus
    taylor50plus Member
    I am now using AMP, for the ads and post, when i look at the AMP version, i do not see the images, how can this be resolved, or where would you find the image url, maybe this can be embedded, this would be too much work though
  2. taylor50plus
    taylor50plus Member
  3. akbar92
    Will you please elaborate your query a bit more with the help of some edited screenshots of the concerned areas of your site.
    Akbar
  4. taylor50plus
    taylor50plus Member
    See attached, in this ad we have a image, not showing in AMP
    Regards
  5. taylor50plus
    taylor50plus Member
    Can someone answer this please.
  6. akbar92
    I just visited your website but didn't notice the issue as you mentioned in the attached screenshot.
    Kindly have a look at the attached screenshot to see the sections.
    Akbar
  7. taylor50plus
    taylor50plus Member
    That`s because you are in normal view and not amp, try putting /amp/ on the end of the url and you will see.
  8. Naveen
    For your information, The theme comes mobile friendly and mobile responsive so you won't need to use AMP .
    If you still want to use the same then, you must contact your plugin author in this regard.
    Regards!
    Naveen Kolhe
