Hello, I try to use Nimble portfolio pugin to the page http://test.powermindsolutions.com/?page_id=160 which im using for tests but images doesnt appear. Please Advice.
Hello, You can get idea from here http://modernwpthemes.com/10-free-wordpress-portfolio-plugin-to-display-your-work/ Thanks & Regards Pramod
Hi, Im Actualy using the 1) Nimble Portfolio But it needs the featured image for beeing able to work good. Regards, Marinos.
Hi, I also try otw-portfolio But the same problem appears. It seem that these errors appears because it doesn't support featured images. can we do something about it? Regards, Marinos Ioannou.
Hi marinos I have checked you site and it's working fine. I am able to see the images. I you still have issues with the portfolio images can you please show your problem with a screenshot. Thanks PankajK
PankajK I have added different portfolio for the specific theme. I dont like it a lot but since i cant use other then i'll use this one. Also Keep in mind that the reason that images dont appear in other portfolios is because the theme by it self doesnt allow you to use the function featured image. is there a possibility to enable it somehow? if this function works then all of those plugins will be compatible with the theme whithout problems. Can you check this out? Regards, Marinos
