Images not appearing on mobile
Discussion in 'BlackBird WordPress Theme' started by pattersp1977, Mar 11, 2018.
  1. pattersp1977
    pattersp1977 Member
    Hi there,
    I am using the Carrier theme of the website www.aviationandmarineservices.ie and the for the slides and the home page section are not appearing on mobile.
    Also, the theme doesn't appear to have a preset page and link in the menu for the home page.
    Can you please advise how to fix these issues?
    Many thanks,
    Pat.
  2. akbar92
    Hope you are doing good...!
    I just visited your website but didn't notice the issue as you mentioned in the attached screenshot.
    Kindly have a look at the video: https://screenpresso.com/=zHNIg
    Akbar
  3. pattersp1977
    pattersp1977 Member
    Hi Akbar,
    Thanks for your response. The issue wit the images appears to be resolved. However, there is no prest page for homepage in the site menu. Can you please advide how I can create this?
    Pat.
  4. Naveen
    Can you please share the screenshot of the concerned area?
    That will be a great help.
    We will check and let you know the solution.
    Regards!
    Naveen Kolhe
