Images Sprites Classicraft
Discussion in 'ClassiCraft WordPress Theme' started by taylor50plus, Nov 11, 2019.
  1. taylor50plus
    taylor50plus Member
    How do we combine images into sprites to save speed up nd optimise the site, or is there someone who can do it here.
    Any help support would be good here, site has to remain the same look
    Rob
  2. shemaela21
    shemaela21 Guest Staff Member
    Warm Wishes From InkThemes,
    Would you please share the URL of the website you are using.
    And let us know about which images you are talking because the links to which you have referred are showing page not found.
    After knowing the information we will let you know the needful.
    Shemaela
  3. taylor50plus
    taylor50plus Member
    https://oxfordlocals.com
    The links above are working, the images are part of the theme, I have just tested.
  4. taylor50plus
    taylor50plus Member
    Can you please help with this issue
  5. shemaela21
    Hello Rob,
    Sprite cow is for a bunch of images to be placed one after the another, with this we combine several images in one image and place them one after the other.
    So, this won't be possible in this case as the images are not placed one after the other just like the social icons are placed.
    And if you are placing one image at a time then this will need customization in the whole website.
    Let me know if there is something else with which we can help you, we will be happy to help you.
    Shemaela
