Import issue - CSV
Discussion in 'GeoCraft WordPress Theme' started by ajohnsonpmo, Oct 10, 2018.
Tags:
  1. ajohnsonpmo
    ajohnsonpmo Guest
    When I import from CSV, it will only import roughly 60-70 items at a time and then it goes to a 'page not found.'
    I have control of my server and added extreme limits on PHP just so I can get the thousands of listings imported.
    The CSV file has roughly 9,000 listings and is less than 2Mb.
    Here is the PHP info that I changed to allow for a large import.
    max_execution_time 100000
    max_file_uploads 20
    max_input_nesting_level 100000
    max_input_time 100000
    max_input_vars 100000
    memory_limit 6144M
    Geocraft V2Version: 2.0.9
  2. akbar92
    Greeting from InkThemes,
    Kindly send the below-mentioned credential details at [email protected] along with the thread link and with the CSV file.
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will do the needful.
