Import not working for me
Discussion in 'GeoCraft WordPress Theme' started by fitnesscoach, Nov 8, 2012.
  1. fitnesscoach
    fitnesscoach New Member
    For some reason the import of .csv is not working for me.
    I'm selecting import/export
    I choose file (.csv)
    I then select import
    no data is populated...
  2. Krish
    Krish Support Staff
    India
    I think the format of your CSV file might be wrong.
    Best thing to do would be to insert a single listing from your WordPress Dashboard, then export the CSV.
    After that open that CSV file in excel or any other similar software and insert data of other listings too, after doing that save the file and import it using the themes Import Tool.
  3. josolomon
    josolomon New Member
    Hi There, I have done exactly that but unfortunately the information populates in the wordpress post section and not under the listing section. why do you think this is happening?
    Thanks for your help.
  4. Nitesh
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    We will check and resolve your issue.
  5. josolomon
    Hi there, i have sent you a message with the login details. but somehow you said my link http://gorobo.co.uk/electriciansswansea/
    is not working? I have sent you also a screenshot to show that the site is working. Please check your email because I have sent you another reply. Thanks.
  6. Nitesh
    Open your csv file and remove blank first row from there and upload it.
    Check image for reference.
