Importing data
Discussion in 'ClassiCraft WordPress Theme' started by jbissitt, Jan 20, 2015.
  1. jbissitt
    jbissitt Member
    Hi I have a few queries re importing data;
    1. Do all records get imported as a free listing?
    2. Can you add images to the import or do you have to add these manually afterwards?
    3. How do you select classification for the import?
    Many thanks for your ongoing help
    Kind regards
    Joel
  2. Pramod
    Pramod Guest
    Hello Joel !
    Free listing will get imported in free and featured in featured.
    You have to add images URL manually on CSV file.
    You can import from Tools => Import.
    Pramod
  3. jbissitt
    jbissitt Member
    Thanks I have downloaded the csv and the advert type is "pro" I presume this is premium? I want to import a lot of records into free listings. I understand all the fields except what do I put into the advert type field for free and premium for the theme to understand how to list the adverts? Thanks
  4. Pramod
    Pramod Guest
    Hello !
    Yes "pro" denotes that is premium.
    Pramod
  5. jbissitt
    jbissitt Member
    If I import then what fields do I need? For example to import data to a free advert what needs to be in this field? Also do the field names need to be exactly the same or can you choose and assign field when you import?
  6. Pramod
    Pramod Guest
    Hello !
    Please Export your some data firstly after creation of fields.
    and then open that file you will get all the fields name as well as values.
    In that file cc_add_type show the type of post free or pro.
    Pramod
  7. jbissitt
    jbissitt Member
    Thanks, so if free it just has free in the cc_add_type then? Kind regards Joel
  8. Pramod
    Pramod Guest
    Hello !
    Yes ! it just has free in the cc_add_type when it is free.
    Pramod
