I need to be able to import duplicates into the directory. I know that duplicates are based on the "Listing Title" column in the CSV file. I actually have multiple locations with the same name so I DO want to import duplicates. Any way I can comment out the php code to make this happen? Thanks, Gary
Hello! Thanks for asking, I have got your concern and would like to inform you that - From CSV file, It is not possible to upload duplicate entries in the theme, You will have to enter your duplicate listings manually either from front-end or from backend. Hope you understand, Warm Regards! Naveen Kolhe InkThemes.com
