Increase Number of Images in Slider
Discussion in 'Harrington- A WordPress Business Theme.' started by niallg, Jul 9, 2016.
  1. niallg
    niallg Member
    I would like to increase the number of Slider Images to 10 in the slider Settings,
    please advise or do you need to do it for me.
    Regards
    Niall
    Hi, Niall..
    Yes we will do it for you but for that, we need to access your dashboard..
    So please send us your dashboard details at [email protected] along with this thread link..
  3. niallg
    niallg Member
    Thanks Priya, I have done so, Also I am having a problem with the thumbnails in the gallery, one of them is a bigger size than the others, and I cannot change the size, also when I make the thumbnails some of the image is cut off.
    Regards and Thanking you in advance
    Niall
  4. niallg
    niallg Member
    Hi Priya, I have sent my details to you, I have also mentioned another query : In the Gallery usually all the thumbnails are the same size, one of them is a larger size and I cannot reduce it to be like the others, Also when I make the thumbnail it cuts off some of the Image.
    Is it possible to make multiple gallery pages with this theme ?
    Thank you again for all your help.
    Regards
    Niall
  5. niallg
    niallg Member
    Hi Priya,
    my apologies I did not think that my preceding message to you had gone through.
    Regards
    Niall
  6. priya
    Thanks for the details, Niall..
    We will get back to you ASAP..
  7. niallg
    niallg Member
    Hi Priya,
    Thank You for increasing the number of Sliders Available to 10
    Best Regards
    Niall
