Info Bar not working
Discussion in 'InkThemes-Support Working Hours' started by realitychurch, Feb 28, 2015.
  1. realitychurch
    realitychurch New Member
    Hello
    I have purchased the info bar pro version but it is not working as when i have the demo version it work properly and showing notification on top , now i purchased and update it to pro it is not creating any entry and can't edit properly while showing me the entry are in plugin
    I Have attached the plugin screen shot let me know what to do
    The website URL IS www.pursuereality.org/beta
    Joe
  2. Pramod
    Pramod Guest
    Hello !
    Your website have some jquery errors may be because of other plugins.
    Firstly deactivate less required plugin then check infobar plugin this will resolve your issue.
    Pramod Patel
