Information in footer panel
Discussion in 'GeoCraft WordPress Theme' started by johnnaismith, Aug 21, 2015.
  1. johnnaismith
    johnnaismith New Member
    Just about finished setting up a new directory site and I have an issue:
    There is some information in the footer panel that I need to change (see attachment).
    How do I remove the existing information and set it up how I want it?
    You can easily replace your existing information as per the requirement.
    You just need to follow the steps according to the video given below.
    http://screenpresso.com/=YKxNb
    Hope it will resolve your issue.
    Inkthemes.com
  3. dontheideaguy
    dontheideaguy New Member
    I have the same question and the link to the video in @priya's response is no longer available at that link.
    dontheideaguy likes this.
  5. dontheideaguy
    Still not sure where the default info that displays is coming from, but your instructions to add information to those blank footer widgets resolved the issue.
    ~DON
