infoway double menu
Discussion in 'Infoway WordPress Theme' started by alaa, Sep 24, 2013.
  1. alaa
    alaa New Member
    Hi there,
    I am using the infoway pro responsive theme.
    I was wondering if there is a way to have a double menu bar.
    One at the top aligned to the left white in color and one right underneath the first one alight to the right orange in color with the menu tabs higher in height so that they over lap on top of the first white menu bar.
    I do not have experience with the coding so i would really appreciate detailed step by step help.
    my website is www.allurebodybar.com
