Infoway menu but not call button
Discussion in 'Infoway WordPress Theme' started by lymey, Jun 14, 2016.
  1. lymey
    lymey New Member
    is there a way to remove the call button (when mobile) but not remove the menu.
    I used this code from a previous thread, it removes the call button but also the menu:
    .menu_bar {
    I now need the menu but not the call button. I am using the latest infoway theme.
    Many thanks!
    .header .contactinfo {
  3. lymey
    lymey New Member
    Hi Priyanka,
    If I just use this code, the call button comes back when the screen shrinks or on a mobile (see attached pics):
    If I use this code, the menu and the call button are not shown at all:
    .menu_bar {
    The same is true if I use both peices of code at the same time. It looks like the call button is asscociated with the menu in some way.
    So unfortunately your suggestion didn't work.
    Any other thoughts?
    Could you please provide us 'URL' of your site?
  5. lymey
    lymey New Member
    roberts-english.com
  6. priya
    I just checked your site and didn't get call button over there...
