Hi guys, can you please look at these 2 issues? I am a NEW CLIENT to inkthemes so I would very much appreciate your prompt attention and expertise when you have a moment... 1. How do I add contact detail to the top right corner under phone number so that I end up with 2+ SEPARATE LINES ? e.g. I want to add address on the second - thirds lines but it keeps adding to thee first line next to the phone number! 2. A bit like 3 but different and regards the footer this time - I want to add text in a SINGLE LINE but it keeps wrapping to a second line which is not what I want. is it a case of increasing the line width? If yes, how?? Cheers Glen PS I have fixed the slider issue I mentioned previously so as of now.. just these 2 issues o/s. Thank!
Hello Glen, 1) Just add </br> tag after your phone number. It will break line and set contact detail to the second line. 2) Please do let me know whether you are talking about footer widget area or about footer bottom area. So that i can provide you exact solution. Also please share your website link. Thanks & Regards Nitesh Raghuwanshi
