Ink Ad Creator: Audio issue ... unable to select "No Audio"
Discussion in 'Ink Ad Creator' started by gloryous, Jun 12, 2015.
  1. gloryous
    gloryous Member
    I'm working on a client's site and have incorporated Ink Ad Creator. Nice concept.
    After testing several of the audio options, I decided I wanted "No Audio." So I selected that option and Saved Change under Publish at the top. However, it won't remove the audio component. The set-up indicates "No Audio" but still plays sound. After exiting the set-up, then returning to it, the Audio Setting option has reverted to the most recent sound selection.
    http://demo77.digitalwordpower.com/
    Am I missing a step somewhere?
    Thank you,
    Glory
  2. praveen
    praveen Support Staff
    Hello, Glory!
    Thanks for pointing out the issue.
    There is a little bug in the plugin.
    We will fix it soon and make available the update plugin in the members area for download ASAP.
    Praveen
