Until I updated my WP framework, my site ran flawlessly and I could update anything. Once I updated to v 5.6 of WP, the javascript crashed and I was unable to edit anything in my widgets. This occurred with both your theme (Menhealthpro) and a different theme from another programmer. That programmer was able to find the java error from your plugin that makes the error occur. Once I deactivated the plugin, I am again able to edit widget content. Will you be updating the plugin to address this problem, or should I use a different appointment scheduling plugin? Thanks, Paul
Hi, Greeting from InkThemes, We need WordPress admin credentials to figure out the issue. Kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will try to fix your issue. Regards, Akbar InkThemes.com
You have been set up on the site and I sent you an email with your login credentials. I look forward to your reply.
Hello, We have successfully received your credentials and is being forwarded to our developers, we will get back to you with a positive response ASAP. Your patience will be highly appreciated, Warm Regards! Akbar InkThemes.com
