Hi, I would like to why Ink Themes are using a dumb date line MM/DD/YYYY ? It is far simpler and easy and understandable to vast majority of people DD/MM/YYYY And because of this dumb format my website has issues. It interferes with bookings and my calender, why put it the wrong way round in first place, honestly? Can I be changed is the big question, I dont like it I dont want it and Im sure most sensible people would agree.
Hello, Frank... Greetings from InkThemes! Regarding Date Format, we are going to release the advance version of the plugin, which will consist of 3 date formats. We will notify you once it got released. Thanks & Regards! Priyanka InkThemes.com
I can't activate the plugin - just updated my membership and downloaded Appointment Way Theme. Building a site at purplewayinc.com/gbfence but the plugin will not activate. Also, it would be nice to be able to change or add fields to the form - I had to find the Submit button and change the text in the code.
Hello, Greetings from InkThemes! To determine and fix the issue, we need to access your dashboard. So, send us your website WordPress login details at [email protected] along with the thread link. Your Website URL: WordPress Username: Password : Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
Enable online booking services on a webpage. Can I be changed is the Ink-Appointment to separate page like http://sospartsauto.com/appointment-booking/. What I'm do... Thanks, Gregory Akko
Hi, Gregory. Sorry, I am a little bit confused with your requirement. Could you please explain it a bit more so that we can better understand your requirement and assist you accordingly? Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
