Ink Page not perfect in iPad. How to correct it?
Discussion in 'InkPage WordPress Plugin' started by sribathi, Oct 9, 2015.
  1. sribathi
    sribathi New Member
    Attached. Please advice
    We have checked your issue at our end and everything works perfectly..
    There must be some CSS loading issue. So I would like to suggest you to refresh the site and look after that.
    Here's the link of what it looks at our end, please have a look: http://actthemes.com/wp7/
  3. sribathi
    sribathi New Member
    Greeting Priya,
    Still same. What you meant about cuss. Where is it? How to correct. Your demo theme, you referred url abovemy theme http://sribathi.com all same.
    Did you checked in iPad landscape view?
    Please check, advice & Suggest
    -Sribathi
  4. sribathi
    sribathi New Member
    Attached a screenshot. What CSS to correct? :)
  5. priya
    Yes, I have checked it on iPad landscape view and it works perfectly at our end..
    Could you please reload or refresh your site for one or two times on the landscape view and check after that.
    Do let me know if you still in same trouble.
  6. sribathi
    sribathi New Member
    It's working great not. Thanks Priya
