Insert Custom Metadata
Discussion in 'Cloriato WordPress Theme' started by jessicalynn83, Jun 22, 2014.
  1. jessicalynn83
    jessicalynn83 Member
    NE Chicago Suburbs
    I would like to add custom metadata into my blog, I have it set up and ready to go, but I don't know where to insert the code to have it appear in on the journal front page and individual posts. I realize this might not be your area of expertise, and more of a Wordpress issue, but I thought I'd ask.
    - Jessie
    For this you can use "All in one SEO" plugin.
    It will provide you option to add meta data for individual page and post.
    Nitesh Raghuwanshi
  3. jessicalynn83
    NE Chicago Suburbs
    Nitesh,
    Thank you for the plug-in suggestion. I think it may be a more robust plug-in than what I'm looking for.
    Here's what I'm trying to figure out: http://codex.wordpress.org/Custom_Fields
    I will keep digging into it and working toward a solution.
    Thanks for your help,
    Jessie
