Inserting a link - text color is light gray
Discussion in 'Blackriders WordPress Theme' started by mschultz33, Mar 14, 2015.
  1. mschultz33
    mschultz33 Member
    When I insert a link it does not show up on the website as a "blue" clickable color link. The link works but it shows up as a light gray color so you can't tell it's a link. Can you please send me the custom css code for that so I don't have to manually do it each time. Thank you
  2. sameerwalkar
    sameerwalkar Guest
    You can use the below code:
    p a {
      color: #F70762;
    Note: you can use your own color code for link-text.
    Sameer
  3. mschultz33
    mschultz33 Member
    Okay I added that and it worked. It also worked on the home page too, except for our the 4 feature circle areas. The color came in the same as the theme and it doesn't look good. Can you help? Attached screenshot.
    In the second circle, "net branch opportunities" is green. Above the circles, it's the blue we changed it too.
  4. sameerwalkar
    sameerwalkar Guest
    To change the link color for below the circle area that you have mentioned in image use:
    .feature_box p a{
    color: #F70762;
    Sameer
