Inserting images into custom widget
Discussion in 'ColorWay WordPress Theme' started by knleib, Sep 16, 2015.
  1. knleib
    knleib Member
    Hi Praveen,
    As per a previous post...
    As you know that these are sidebar widget area. So, it would displayed in all the pages.
    But don't worry!!!
    There is an alternate solution, we can hide different widget in different pages using CSS.
    Please insert video/images in the sidebar and notify me which widget you want in which page ( through some edited screenshots ) .
    I will provide you the required CSS code :)
    Praveen
    Can you help me to insert two images into my Recipe Page please? They are already in my library. If I add them into my widget, they will show up on my blog and as we did custom coding for my recipe blog, I want these to go here (where the 2 black images are) only. I will be sending a new video to be at the top but you can leave that one there for now. Thank you.
    We have customized your theme as per your requirement to show two images in your Recipe page only.
    Kindly check your site and reply.
  3. knleib
    knleib Member
    Thank you very much. Is there a way to adjust the spacing to be even between the video and images? Also the width to be the same?
    Also I want to link the bottom image to my mailchimp and the middle one to a future post. How do I do that as the inserting the mailchimp code doesn't seem to be working. Thanks.
    We have fixed your issue of the spacing between video, images and width as well.
    Sorry for the second issue, We didn't get that....
    Could you please elaborate a bit more with some edited screenshot so that we can assist you accordingly?
  5. knleib
    knleib Member
    Thank you. It looks better now.
    I want the bottom image "sign up for our newsletter..." to be able to be clicked on and open in a new window that is my mailchimp sign up form. I did this on my contact page with the image there. Just not seeing the same option for this image in the widget. How do I do this please?
  6. knleib
    knleib Member
    I just took a look at my site and the bottom image is now inking directly to my contact page. I want this to link to my mailchimp sign up form...the shortcode should be inserted into the image url. I only mentioned the contact page above as a reference for what I meant. I would do this myself but it isn't linking probably due to its location. Thanks.
  7. priya
    Could you please provide us your MailChimp shortcode at [email protected] and we will do it in your dashboard through your provided credentials earlier?
  8. knleib
    knleib Member
    Sure.
  9. priya
    We have resolved your issue..
