Installation Problem
Discussion in 'BlackBird WordPress Theme' started by eurobiketrans, Feb 7, 2014.
  1. eurobiketrans
    eurobiketrans New Member
    Dear Inkthemes can someone give me so advice and suggestions on corrective action please. I've just finished writing my first WordPress site on ServerPress, and am trying to uploaded what I thought was the correct files and database onto the host UK2.
    Here's what's wrong.... On my own home computer the site looks fine, with everything visible and functioning, apart from the email links in the contact page don't seem to be going anywhere, plus when I type in the sites URL, it immediately loads up, but the dashboard bar and drop down menu automatically appears without me typing in the normal wp-admin extension on the URL.
    Big problem is that when I try to open the site from another PC or mobile devise the site functionality and appearance is lost, I just see a list of pages and sections.
    I'm well behind my deadlines now to get the site up, can anyone please help me? plus can you please keep your suggestions in very simple terminology because I am very new to this world... You can look at the incorrect site on www.eurobiketrans.co.uk thank you v much Tony
  3. eurobiketrans
    Hello and thanks for your reply Piyush Pratap. Appreciate your comments. I've now managed to launch the site on http://www.eurobiketrans.co.uk My problem now is that I don't seem to be able to get any email to be send from the contact page. Can you take a look for me and advise what I need to go to enable emails. Thanks very much, Good day, Tony
  4. Piyush
    We have checked your website, it seems that you are not using theme default contact page.
    I think you are using any plugin for that contact form, so for this issue contact with the plugin related support forum.
    Or
    You can use theme default contact form.
    Go to the Pages > Add New panel in your dashboard and create your contact page by selecting Contact Page template from Page Attribute section and then publish the page.
    After that go to the Settings > General panel in your dashboard and put your email id in the E-mail Address section.
    You will get all the contact leads on this email id.
