Instead of "view older posts" or "view newer posts" change to...
Discussion in 'HomeBuilder WordPress Theme' started by v4sb, Oct 27, 2015.
  1. v4sb
    v4sb Member
    Instead of "view older posts" or "view newer posts" , I would like the text to say "view older listings" and "view newer listings"
    smith likes this.
  3. v4sb
    v4sb Member
    The website is not live at this moment. Here are screen shots. [​IMG][​IMG]
    For your knowledge, I am using wp-editor plugin to edit the file.
  5. v4sb
    v4sb Member
    I just tried this and do not see the change when I refresh the page?
  6. priya
    Could you please send us your dashboard details along with this thread link at [email protected] and we will do it for you?
  7. nitin
    nitin Guest
    You would be glad to know that we have made the changes in your website as per your requirements.
    We have also replied you on mail.
    Kindly check and acknowledge us for the same.
    Nitin
  8. v4sb
    v4sb Member
    Awesome!! Thank you guys - again! You have the best support, hands down, that I have seen...and that is why I continue to use you guys.
