Internet Explorer Issues
Discussion in 'Figero WordPress Theme' started by galesburgpl, Aug 21, 2013.
  1. galesburgpl
    galesburgpl Member
    Firefox and Chrome display the website fine, but when viewed in I.E., several things are wrong. The header logo has poor resolution, the drop-down menus go behind the slider images and text, and the slider arrows initially display on the top of the header rather than in the middle.
    The website is http://www.galesburglibrary.org/a/
  2. galesburgpl
    galesburgpl Member
    Update: I have resolved the poor resolution issue with the header logo, but the menu problem persists.
  3. Piyush
    We have checked your website and it is looking fine in IE.
    If you are still getting the problem then please specify the version of IE in which you are getting the issue.
  4. galesburgpl
    galesburgpl Member
    I am still having trouble. I am using Internet Explorer 10 (version 10.0.9200.16660, specifically).
    Attached is a screenshot of what I am seeing, with the problem areas circled. Untitled.jpg
  5. Gourav
    We have checked your website and it is working fine, Please set your IE in standard mode, If it is running in compatible mode and also clear your browser cache, It will resolve your issue.
