Hello, I want to add the AdSense Auto ads (https://adsense.googleblog.com/) In accordance with the guidelines must: Paste the ad code between the < head > and </ head > tags of each page where you want to show Auto ads. Auto ads will start to appear on your pages in about 10-20 minutes. I tried to past but anyone ad showing! i need you help... THANK YOU!
Hello, Thanks for contacting us, I got your concern and would like to recommend the below-linked plugin in this regard. 1. https://wordpress.org/plugins/adsense-plugin/ Hope this helps...! And if you want to add it manually then just share the edited screenshot of the concerned area of your website where you exactly want to show the ad. So that we can assist you accordingly. I look forward to hearing from you. Regards, Akbar InkThemes.com
HELLO! thank you for your answer, i installed My AdSense Auto ads Code in my header.php (before </head> tag) please check if its correctly installed... THANK YOU!
