Is it possible to add in additional widgets to One Page Pro?
Discussion in 'One Page Pro WordPress Theme' started by dynamicpear, Aug 5, 2016.
  1. dynamicpear
    dynamicpear New Member
    Hi
    Is it possible to add in additional widgets to the theme?
    The customsed widget for the homepage isn't working that well and doesn't give us the flexibility we need, to add in larger images or multiple styles for the body text.
    Jason
    Hi, Jason..
    Could you please send us screenshot of the concerned area where you want to add widget option so that we can assist you accordingly...?
