Is it possible to have the tap to call feature on the homepage?
Discussion in 'GoldenEagle WordPress Theme' started by vblaes, Feb 25, 2014.
  1. vblaes
    vblaes Member
    for the Golden Eagle themes, is it possible to have the tap to call feature on the homepage? Also, what about putting the companies address and email on the far right of the header above the slideshow? I really like the look of this theme as does my client but having the tap to call feature is important. Also, when looking at the demo, each time I would pull down the menus on the mobile template, it would go right back up? Why does this happen? Thank you. valarie
    Currently theme don't have space in the header area to add content you are asking.
    Adding content there require editing in theme's layout and style.css.
    It's a time consuming process. Please call a free lancer for it.
    Nitesh Raghuwanshi
  3. vblaes
    vblaes Member
    I am a freelancer, and have purchased several themes from you all to develop sites for my clients. This is a disappointing response.
    In the past, CSS code was provided as part of tech support. Is this not the case any longer? What about the problem with the menus going back up when trying to pull down?
    Is there a similar theme that has the tap to call feature?
    Thank you.
  4. Piyush
