Is this a tap to call theme when viewed on a phone?
Discussion in 'Appointway WordPress Theme' started by leadology, Aug 7, 2017.
  1. leadology
    leadology Member
    Thanks!
  2. akbar92
    Will you please elaborate your query a bit more, I didn't get it properly. Also, please share some edited screenshots concerned areas of your site.
    So that we can deliver you an exact and appropriate solution to you.
    Akbar
  3. pauljw
    pauljw Member
    Yes, it is.
    akbar92 likes this.
