Hi there Ink Themes! The footer has seemingly been removed from the home page, but not on other pages. How do I get the footer back on the homepage? Also, where do I change the widgets in the footer? I do see that in theme options. www.LinxGolf.com Thanks! Ronnie
Hello, Download a fresh copy of latest theme from members area and upload it to your website. That will resolve your issue. Thanks & Regards Yogesh Bhade
How can I do that without overriding the changes that I made to the site and the images, etc.? When I try to upload the new update, it says the folder already exists so that means I have to delete the old one first. I fear I will lose the work I have done. Also, is there not a way to get auto updates for the theme? I just have to check the Members area all the time?
Hello, You have to delete your current theme then update your theme. If you have did customization then it will be lost, If you did some styling changes by Custom CSS then it will not lost. You have to check in members area for theme update. Thanks & Regards Yogesh Bhade
I was able to update, thanks! One thing that is not clear, where can you update the Sidebar Widgets for the Normal Page layout? Example: http://fullswingent.com/what-we-do/catered-meals/
Hello, You can update sidebar widget for the normal page layout by using widget option of your dashboard. Go to your wordpress Dashboard ==> Appearance ==> Widgets and manage all type of widgets. Thanks & Regards Yogesh Bhade
