I have a few issues when translating all the words: 1st I cannot translate "Listing Title", and "Enter Listing Title", also these do NOT APPEAR in the "custom fields" section of my geocraft settings http://www.zweitbuch.org/Marktplatz/add-new-listing/ 2nd where can i translate "cost" and "valid up to 4 months"??? http://www.zweitbuch.org/Marktplatz/add-new-listing/ 3rd The dates and expiries in the dashboard are still in english http://www.zweitbuch.org/Marktplatz/dasboard/ 4th change word "page" in review section http://www.zweitbuch.org/Marktplatz/dasboard/?action=review 5th the words "Rating" and "No Review" in the single listing show http://www.zweitbuch.org/Marktplatz/listing/testi/ please please help!
Hello, 1) Go to the geocrafttheme\library\controls\admin_setting\custom_fields\manage_custom_field.php It will enable listing title in the custom field. After this you can change title from custom fields. Check image for reference. 2) Go to the geocrafttheme\library\front_end\listing_submit_form.php 3)geocrafttheme\library\controls\dashboard\dashboard_functions.php 4)geocrafttheme\library\controls\dashboard\dashboard_functions.php 5) geocrafttheme\library\text_domains\template_path.php Thanks & Regards Nitesh Raghuwanshi
thank you very much nitesh, all worked out ! but two things for 3) i meant the actual values of these fields, so for example "24 March 2014" or "119 days, 10 hours left" i want to translate this texts to german!! and 4) did not work...
3) Theme taking date from WordPress. So the date format and language on which your WordPress is set will display there. 4) That page contain "page" text at 6 places. Make conform that you are changing text at line number 628. Note: Please use child theme for these changes. Thanks & Regards Nitesh Raghuwanshi
