I've noticed when I go to my website using Google Chrome a couple things happen: 1. The header images/slide show does not load. 2. The Testimonials section lists all 3 testimonials at one time. (I've attached two screen shots so you can see what I mean) This happens more often than not. When I use Safari, this does not happen. Is this an issue w/ Chrome or something I can adjust in the theme to fix? Thanks, Kelsa www.FiscalFitnessPHX.com
