I am having issues where I create a feature and then when I go back to it the page is gone? Also, is there a way to either move the sidebar to the right or make it so the mobile version puts the sidebar content below the page content? The responsive look is great however I prefer my main content to be on top versus my sidebar content. Any help would be greatly appreciated. Thanks, Doug
Just to help, my website is www.rellaroo.com, let me know if you have seen this issue before and if the sidebar is able to be moved. In the notes of the file is states left or right sidebar but I cannot find the area where I can change that.
Hello ! Do you want the sidebar on right side? Please follow below image to do this. You have to do the same process in page.php, blog.php Thanks & Regards Pramod
Having an issue with the Tilala theme we downloaded from your site. It appears to be missing the CSS Style sheet. Can we get this zip file updated or can I get a refund? site is www.theclasseywifey.com We are receiving the message in Wordpress when we try to upload the theme: Unpacking the package… Installing the theme… The package could not be installed. The theme is missing the style.css stylesheet. Theme install failed.
Hello Doug! First of all extract the zip file which you will get. After that search another zip file inside it with theme name. Install that file as a theme this will resolve your issue. Thanks & Regards Pramod
Having an issue with chrome browser not loading the home screen correctly. Using your Foogo theme and it looks great except..... Its is wrapping the products in the four column area so only three show on the line and then there is white space and the fourth column in on the next line. It looks normal in Safari only issue in Chrome so far. Can you test and see if you have the same issue and what me causing it? www.rellaroo.com is the website
Hi rellaroo! We have checked your website on chrome and everything works fine. Just have a look at the video link given below. http://screenpresso.com/=ypCSe Thanks, Praveen
Hey, I'm building a website which has only one page. So I would like to remove the Home button and the lines. Is this possible: www.test.autoberging.nl Thanks in advance for your reply.
Hello brightappdesign! Please paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: .menu-bar { display: none; } Thanks, Praveen
