Issues with header size, Infoway Theme commercial and Post carousel
Discussion in 'Infoway WordPress Theme' started by bjoernjohansen, Nov 2, 2013.
  1. bjoernjohansen
    bjoernjohansen New Member
    Denmark
    Hi there,
    I just updated to the last version of Infoway. I have a child theme for this. This led to to issues I cannot solve. I feel confident that you can help me with this. I have enclosed a file for reference. You may also have a look at www.bjoernjohansen.dk
    Header size
    Untill I Updated I had the correct size for the header photo. Not it does not look good at all. I have checked the Custom CSS, which is still
    #featured .ui-tabs-panel img {
    height: 40%;
    #featured {
    height: 145px;
    I like the infoway theme, but is not thrilled with the infomercial stating name of theme. How do I remove this? Furthermore I would recommend that you delete this solution. I suppose most people will remove it anyway - some first through a cry for help
    Post carousel
    I don't recall to have seen this in the earlier version 1.5.5. I would like to get rid of it. How do I do that? And where are the controls for this feature? Just in case I should change my mind.
    Best regards
    Bjørn Johansen
  2. bjoernjohansen
    Denmark
    I have solved the issue about the Infoway Theme commercial. One down, two to go...
  3. Piyush
    1. For the Slider issue,
    paste the following code in your Custom CSS
    .showcase-content img {
    height: 40%;
    2. It is the feature of our theme to display excerpt view of latest blog post on the home page.
    The latest post that contains the image(s) will only display in the post carousel of home page.
    If you want to remove the post carousel from the home page then paste the following code in your Custom CSS
    #carousel-full {
  4. bjoernjohansen
    Denmark
    Thanks. Did the trick as wanted.
