In the Homepage Second Featured Section - First Feature Section we added a h2 title and some text in html, because this section does not have a title field. But this causes the titles of sections/columns to not align in height. Is this because of the top margin or padding of the h2? How can we solve this for this specific section only? Also the Third Feature Section Right Column can contain an image. How do we add links to these items? In the theme options we can only upload an image. Thanks.
It's been over 2 weeks now. Could we get an answer asap? Also the image in the mentoined section is not shown correctly on an iPad. It's rotated 90 degrees?!
Where can I find the updated version? Where's the information about the update itself? I also cannot find any notification about an upgrade being available.
You can find updated version of theme in your members area, Login by link given below http://inkthemes.com/members/member/index Go to http://www.inkthemes.com/ and enter your name and email address in the text box given there, At the time of update we will sent information to you.
It's been a while, but we are now looking into this issue. You say that I can find an updated version of the theme in my members area. Do you mean under Active Resources and then the theme zip file? How can I see that this is an updated theme? What version is this? Am I not just downloading the same theme as I'm using now when I do this?
1. Firstly check your existing theme version, Go to the Manage Theme tab (Appearance -> Theme) in your dashboard and there will you get to see the version of the theme in the top center behind the current theme screenshot (click on link for the reference http://content.screencast.com/users...3e-4f2d-a2e7-abe6ee8e2bbd/2013-03-22_1233.png). 2. Secondly check the version of current downloaded theme from members area , Unzip that downloaded file a). Go to the style.css file(Theme directory -> style.css) present in the theme directory, open it , there you will get the version of the theme at the line number 7. b). And then go the changelog.txt file (Theme directory -> changelog.txt), open it , there will see the latest updated version and their changes. NOTE: The latest updated version of the Themes are only present in the Members area.
