issues with theme
Discussion in 'Slice WordPress Theme' started by katsnus, Nov 20, 2017.
  1. katsnus
    katsnus New Member
    I just purchased the slice pro theme for WordPress. I have some issues hoping you can assist me.
    • In header section, next to the search, we would like to remove "view your shopping cart" from header.
    • In the footer section 3, all contact plugins show a black paragraph box for comment section, need white.
    • Is there an option to tell theme not to hard crop featured images.
    • Is it possible to have full width format for post, product pages and category pages. Removal of sidebar widget.
    • how do we change the color and font of the wording in the homepage banner.
    website is: www.katsnus.com
    Thank you,
  2. akbar92
    We need WordPress admin credentials to make desirable changes.
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    Just paste the code given below in Custom CSS section.
    .footer-container .footer .footer-wrapper textarea {
        background-color: #ffffff;
    It requires some manipulation in the source code of the theme, Kindly send the WordPress admin credential details at [email protected]
    Please, send the WordPress admin credential of your website.
    Use the below-given CSS code.
    .banner_details font {
        color: #ff0000;
        font-family: monospace;
    Note: Use desired color code and font style.
    Do let me know if you need further help.
    I will glad to assist you.
    Akbar
  3. katsnus
    katsnus New Member
    Thank you for the assistance. At this point we are going to hold off on changing the side widget. We might use it differently as it is. We figured out how to stop the shopping cart in the header. Thank you for the other information.
    We do like this theme. It was an improvement over our old one.
  4. akbar92
  5. tophealth
    tophealth New Member
    Hi, Any instructions on how to install the vitaminshop theme?
  6. akbar92
    To install the theme with the demo content, Just visit your member's area: https://www.inkthemes.com/members/member
    Get download the zip file of your theme along with JSON and XML files.
    Now, visit your WordPress Dashboard->Appearance->Themes->Add New->Upload
    Upload & activate the theme and also install the Ink Import Export plugin.
    By using our import export plugin, you can upload the demo contents (XML and JSON).
    I hope you find the above information helpful.
    If you still unable to install demo content then just send the below-mentioned credential details here.
    We will do it for you.
    Regards!
    Akbar
  7. cmballard
    cmballard New Member
    I use the slide theme but Godaddy updated to wordpress 5.0 and ever since I've had terrible page load times. Godaddy says the theme does not work on 5.0. Is there anything you can do to help me? I really like this theme but I will have to change it if I can't get it working soon.
  8. shemaela21
    shemaela21 Guest Staff Member
    Warm Wishes From InkThemes,
    We will let you know the needful.
    Shemaela
