Items, when updated, default to DRAFT when published.
Discussion in 'ClassiCraft WordPress Theme' started by chester29, Oct 24, 2017.
  1. chester29
    chester29 Member
    France
    Recently I've had no problems with this theme but yesterday when maybe 20 items reached their expiry date they default to DRAFT when the date is extended and published.
    I've tried several times to get the items to publish correctly but they all revert to DRAFT and so don't show up on the website.
    I've been through and "turned off" all plugins in case that was the problem.
    I think that mayce Wordpress has been updated recently - could this be the problem ?
  2. chester29
    chester29 Member
    France
    Well I think I've solved this one.
    Previously I had entered the expiry date as : mm/dd/yy and this had worked ok - maybe this was using a different issue of the WP.zip
    I found that if I entered the expiry date as : dd/mm/yy then this worked ok - this was using the latest zip.
    So problem solved !
    Thanks.
  3. chester29
    chester29 Member
    France
    Just some more important information regarding expiring Ads.
    When an Ad expires and reverts to draft mode it also removes any Google Maps information from the site display.
    I had found this a long time back but obviously nothing has been done to correct it happening.
