JavaScript issue in Infoway
Discussion in 'Infoway WordPress Theme' started by bjoernjohansen, Nov 1, 2013.
  1. bjoernjohansen
    bjoernjohansen New Member
    Denmark
    I want to integrate Hybrid Connect to my website www.bjoernjohansen.dk, where I use Infoway as a template. The developer of Hybrid Connect informs me that errors in the template disallows be to do so. Is that something you are able to fix?
    Best regards
  3. bjoernjohansen
    Denmark
    Hi Gourav,
    Thank for your answer. I have downloaded and tried to upload the new version in the ZIP file, but gets the message, that the folder all ready exists. I have a child theme in place. Should I rename the old version through FTP and then upload the new version? What is the better way to approach this?
    Best regards
    Bjørn
  4. Piyush
