The sliders on my home screen jump as they are transitioning. I deactivated each plugin to find out which one was causing the problem and found out it was Jetpack. Once Jetpack is deactivated the problem went away. I would like to be able to use Jetpack. My site is http://www.wptoys1.com/barbie/. Thanks!
Hello, Greetings from InkThemes! To determine and fix the issue, we need to access your dashboard. So, send us your website WordPress login details at [email protected] along with the thread link and we will check the compatibility issue with the theme. Your Website URL: WordPress Username: Password : Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
