job manager not display lisitng when working with geocraft theme
Discussion in 'Circles Gallery WordPress Plugin' started by asaran, Sep 16, 2015.
  1. asaran
    asaran Member
    hello, i installed job manager ( https://wordpress.org/support/plugin/wp-job-manager) is working ok, but is not showing nothing of the job listings! can you help me with that ? i make sevaral testing but unfortunatly is not showing the listing on thge broser...
    When I used the plugin at our end it works fine and even all the details are visible in the job listing field.
    Here I am providing you a video related to adding jobs please have a look over it:
    Link of the video: http://screenpresso.com/=IQbAf
    If you still have the same issue then please provide us your dashboard details at [email protected] so that we can have a look over your issue and try to fix it.
  3. asaran
    asaran Member
    Could you please provide us your Dashboard credentials at [email protected]?
    Reason behind of asking the details is when we have checked and run the same plugin as you provided the link above at our end it working all good so we want your credentials to have a look over your issue and able to resolve in your dashboard.
