I'm getting a javascript error when using the pro theme, in the current release of the theme in Wordpress 3., in chrome: "Uncaught ReferenceError: jQuery is not defined " and the error is being spawned by the "leads_form/demo.js" file, which it appears is being loaded before jquery is loaded, as you can see below, taken from my wordpress page. <script type='text/javascript' src='http://henb.ca/wp-content/themes/infowaytheme/functions/leads_form/demo.js?ver=3.9.2'></script> <script type='text/javascript' src='http://henb.ca/wp-includes/js/jquery/jquery.js?ver=1.11.0'></script> The site is at: http://henb.ca Thanks!
also, this error pops up, even when I hack in a fix to jquery being missing by adding a reference to it to the "headers.php" file. Uncaught TypeError: Cannot set property 'className' of undefined ddsmoothmenu.js?ver=3.9.2:50ddsmoothmenu.buildmenu ddsmoothmenu.js?ver=3.9.2:50(anonymous function) ddsmoothmenu.js?ver=3.9.2:137j jquery.js?ver=1.11.0:2k.fireWith jquery.js?ver=1.11.0:2n.extend.ready jquery.js?ver=1.11.0:2K jquery.js?ver=1.11.0:2
and the reason the 2nd error is happening is because ddsmoothmenu.js is assuming that there's a "main menu" with a UL there, but I have that feature disabled on the home page. So the code below should be change from this: buildmenu:function($, setting){ var smoothmenu=ddsmoothmenu var $mainmenu=$("#"+setting.mainmenuid+" ul") //reference main menu UL $mainmenu.parent().get(0).className=setting.classname || "ddsmoothmenu" ... to something like this: buildmenu:function($, setting){ var smoothmenu=ddsmoothmenu var $mainmenu=$("#"+setting.mainmenuid+" ul") //reference main menu UL var m = $mainmenu.parent().get(0); if (m != undefined) ....
