keep my header on all post and pages
Discussion in 'ReThink WordPress Theme' started by war8769, Aug 23, 2013.
  1. war8769
    war8769 New Member
    when i create a review post, my header is gone and i have no navigation up top. on a simple post i have the header and navigation. i can see from other sites that the header is there but not on mine.
    http://bestproductsontv.com
  2. delkko
    delkko New Member
    I also I have the same problem when I do a review post, the header, menu and the other elements vanish. I understand it is a full-sized post, but I want to display the header or any option for visitors to easily access the home page at any time, otherwise I find that visitors can get confused and leave the very fast page.
    This is what I mean:
    http://andesken.com/juego-de-mesa-para-android/
    Thanks for your help, I hope to answer these questions.
  3. Piyush
  4. Piyush
  5. delkko
    delkko New Member
    No, not at all, I've downloaded supposedly the theme in version 2.0.5 and upload via ftp the theme shown is the version 2.0.4. So I get in Wordpress:
    Screenshot from 2013-09-04 16:06:56.png
    The only thing that has changed is that the parts of the theme that had already translated into Spanish language are my new account in English. The post of review is the same without the header.
    Screenshot from 2013-09-04 16:09:34.png
    I have looked also from the Changelog file hosting effectively indicates that the issue is the version 2.0.5, so I do not what happened.
  6. Nitesh
    Please download file attached "customsinglepost.php" and replace it with current theme file.
    You can also replace file code through your dashboard.
    Appearance > Editor > customsinglepost.php
  7. delkko
    delkko New Member
    Thank you very much, the problem is solved, now displays the header, but I'd like to tell me how I can change the text of this button?,. I need to edit the button image or can be done from any theme file? ..
    thanks
    Screenshot from 2013-09-06 16:46:58.png
  8. Gourav
    Go to images directory present in your theme directory and replace your image with present visit the site button image or edit it.
    The name of image is "visit-btn.png"
  9. delkko
    delkko New Member
    Thank you very much., I have placed the image and hopefully edit or create my own button. Thank you for solving my doubts.
    greeting
