Hi I'm looking for a language bar, that displays flags, which I can use in a multisite installation. I'm going to use the flags as links between the sites. I tried Language Bar, but it made an error to my mobile navigation bar. Hope that someone can help! Thanks
Download qtranslate plugin from WordPress.org http://wordpress.org/extend/plugins/qtranslate/ Also check the link given below, I hope this will help you http://www.inkthemes.com/how-to-translate-your-wordpress-website-using-qtranslate-plugin/01/
Thanks for your answer. I'm looking for a plugin like "language bar flags". As I understand qtranslate is a plugin which can translate your content..? Thanks
