When using the contact form to send admin a message there are a few problems I need to know how to solve. First the subject line, now it looks like this: [PHP Snippet] from Stefan How to remove that "PHP Snippet" part and second how to customize it as I want it, like: "Message from mysite.com" or something similar ? Second, my site is in Swedish and when I type in Swedish characters in the body text it really looks bad and looks like this: I type in: åäö ÅÄÖ It it become: åäö ÅÄÖ This I also need a fix for as soon as possible ... Beside above, I like your theme(s) and plugins so I hope my problem has a quick fix /Stefan
Hello, Hope Doing Good. For your first issue, Kindly follow the below step mentioned in the image. For your second issue please send us your WordPress dashboard admin login details at [email protected]. so that, we can have a look over the issues in detail and will try to resolve them ASAP. Your website Login link: WordPress username: WordPress password: Note: Once your issue get resolved, you can change your password. Hope it will solve your issue.
My first problem solved, I got that "PHP Snippets" removed now I also sent you a mail with url and login info so you can look at and fix my secont problem with foreign characters like åäö ÅÄÖ in those contact emails the site send ... /Stefan
Hello Stefan, Greetings from InkThemes, Kindly check we have fixed your issue, Thanks for your cooperation. Hope you are enjoying InkTheme services. Do let me know if you need any help.
Thank's, I just tested and this is what I got in body text: Comments: Test åäö ÅÄÖ Works like a charm May I ask what the problem was and what you did ? ...and will this fix be included in your distribution files, when new versions released? /Stefan
Hello Stefan, Hope Doing Good, I have attached the screenshot where I have mentioned the area where I changed, Hope you are enjoying InkTheme services. Do let me know if you need any help.
