Hello, how can I do more language versions of the site? Work page is: www.autocamplevoca.ferix.sk Thanks a lot
Hello, If you want to translate the theme in one language then follow the link given below http://www.inkthemes.com/how-to-cre...-of-wordpress-theme-in-multiple-languages/02/ If you want to translate the theme in multiple language then you can achieve this through 1. qTranslate plugin, See the link for reference http://www.inkthemes.com/how-to-translate-your-wordpress-website-using-qtranslate-plugin/01/ Or 2. Google Language Translator plugin, See the link for reference http://www.inkthemes.com/make-multi-language-website-by-using-google-language-translator-plugin/08/ I hope this will help you. Thanks & Regards Gourav Shrivastava
