I have read your other threats on the fact that only PRO works well with qtranslator capability. That is whyI changed to PRO. I originally had Catalan as my language by default. Now I can also edit pages in English. The page title and page menu changes but the content does not show in english. Also in the theme page when I use the <!- -:ca- ->Your text in Catalan.<!- -:- -><!- -:en- ->Your text in English<!- -:- ->. It does not work. BOTH texts appear when choosing English. Can you tell how to fix both issues? Data point: www.eixverd.cat, WP 4.4.1, qtranslate2.5.39 and I am also usind siteorigins.
Hi, Try and follow the steps mentioned in this post: http://www.inkthemes.com/how-to-translate-your-wordpress-website-using-qtranslate-plugin Hope it will solve your query. Thanks & Regards Sameer Khanwalkar
I had already seen that link. That link is the one that made my buy the PRO section since it was said that qtranslate only works in the pro vertion. My default language is catalan. Second language english. In section 6 when editing the home page: When I try <!- -:ca- ->My text in catalan.<!- -:- -><!- -:en- ->My text in English<!- -:- -> It works when I select the language selector to Catalan but when I chose English in language selector it shows BOTH text strings ('My text in catalan. My text in English') When editing a regular page: Since I am using Siteorigin, I need to switch back to editor in ordet to see the two language tabs. Then I translate from Catalan into english in the english tab, but when refreshing the page and amking sure I choose English in the language selector, the english translation ONLY is obvious in the title of the page but not in the content. Grateful for some help Lidia
Hi, Due to latest version of WordPress qtranslator is unable to make its effect for language translation. So i would suggest you to go for:- 1 .po file - http://www.inkthemes.com/how-to-cre...ion-of-wordpress-theme-in-multiple-languages/ 2. Google Translator plugin - http://www.inkthemes.com/make-multi-language-website-by-using-google-language-translator-plugin/ Regards, Sameer
