Hi, I bought a plugin "layer slider parallax effect" and does not work with colourway pro. Help please.
We have check that plugin with Colorway theme it is working fine, If you are not comfortable to run that plugin then send your wp-dashboard id, password and dashboard login page link with problem description at [email protected] And also specify in which page you want to add that plugin.
I want to replace home page slider . www.retouchbox.com. I have already install layer slider but I don't know how to put on the front page. I can't find options to replace.
Unfortunately there isn't a way to do that with our theme unless you custom code something up. Sorry. If this isn't something you're able to do then you would need to hire a developer for this. Take care.
