Hi a couple of issues on the site at http://smartawordpress.com/ 1. I'd like to make the slider (in this case it is only a single image) about one third of the current height I've tried lots of CCS tweaks but can't seem to get it 2. I'd like to make a permanent line break in the menu so that "Recent Projects" and "Contact" both stay on the 2nd line (because the menu items have 2 or 3 words they tend to break awkwardly) I hope you can help!
Hello Smarta, 1) It's not so easy to make your slider image's height to one-third as it will require lots of changes from the source code. 2) Regarding the menu item, you need to paste the below custom CSS code in Dahshboard->Appearance->Theme Options->Styling settings->Custom CSS field. Code: #menu .ddsmoothmenu li a { padding: 5px; } This will help you to figure it out and resolve the issue(s). Warm Regards! Naveen Kolhe InkThemes.com
1. you guys have been able to adjust the size of sliders on other Ink Themes I have purchased - why not this one? 2. that css does not help - it puts contact on 2nd link - but when the screen is smaller is moves the "list" from the next menu item down (therefore breaking the 3 word menu item) - I want each menu item (regardless of the number of words) to stay together
Hello Smarta, We can change the slider height but it will require lots of changes from the source code and stylings in your site, It will be time-consuming as well. Regarding the menu, I have checked your menus and it is appearing fine, but for small screen, you must use below code to get the menus in proper alignement Code: @media only screen and (max-width: 960px) and (min-width: 767px){ #menu .ddsmoothmenu li { margin-right: 15px; } } Warm Regards! Naveen Kolhe InkThemes.com
