I tried to change the text for the Lead Capture Form Heading (under the Theme Options) and it didn't work. Am I missing something? Also - how do I change the header background color to Orange.
1.For your first issue Go to Appearance > Theme Option > Lead Capture Settings > Lead Capture form Heading and enter your text there and save the changes, This will solve your issue, If not then please check that you are not using any cache plugin, if using then clear the cache and also check your site at any other browser. 2.For your second issue Paste this code in Custom CSS Appearance > Theme Option > Styling Option > Custom CSS Code: .header { background-color: orange; }
Thank you . I did both of those things. I pasted the code for the orange background and this is what happened. see image -- issue1.jpg The two orange bars above and below my header are not supposed to be there. For the form itself - I followed your instructions, don't have any cache plugins and looked at it in another browser(Safari) and it didn't change at all. Any suggestions ? I need the background color on this lead capture form to actually be #CA4E11
Hi there, I also tried to change the text for the Lead Capture Form Heading (under the Theme Options) and it didn't work. When I refresh the page after saving the options, it reverts back to a blank text box. I cleared the cache and deactivated all plug-ins too. Please help!
Please provide the following information listed below. Thread Link: Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected]
