Lead Capture Form not Working
Discussion in 'Lead Capture WordPress Plugin' started by bcv5431, Mar 27, 2015.
  1. bcv5431
    bcv5431 New Member
    I purchased the Appointway theme as well as your 13 plug in deal, but I cannot get the Lead Capture Form to work.
    There is an error message showing up on the form that says, "Input error: k : format of site key was invalid" How do I fix this? What is a site key? Please help asap.
  2. sameerwalkar
    sameerwalkar Guest
    This error is because you have not configure your Google reCaptcha. To configure Google reCaptcha you need to get it from : https://www.google.com/recaptcha/intro/index.html
    After registering you will get a reCaptcha Public and Private key. That you need to paste as shown in the image below:
    Do the above steps it will solve your issue.
    Sameer
